CIE PTL-1 Fuse
Hi
Okay. The two PTL-2 fuses are taken care of.
Thanks to Verna and David.
The PTL-1 fuse seems to be a 1 1/8" long fuse.
Looks like for good reason.
A 1 1/4" seems to bottom out with spring loading.
Will post markings on existing fuse.
Bob
Hi
Here are the markings on the ‘short’ fuse.
JEF250V 1A
Do 1 1/8" fuses exist?
Have a good evening
Bob
do you mean Click here
Hi Robert
Thanks
Those look like 1 1/4" fuses.
This fuse that came with the PLT-1 really is shorter than that.
It really does measure 1 1/8"
It is a better fit in the fuse holder too.
Swapped in 1 1/4" fuse and it did not feel good.
Did not know if cap was screwed all the way down or fuse was bottoming out.
Have a good evening
Bob
perhaps this may help Click Here
High quality fuse holders often have high pressure on the fuse contacts. This significantly increases long term reliability and lowers electrical resistance of the fuse circuit.
Lower pressure fuse holders will often require removal and reinsertion of the fuse every few years to keep the electrical resistance low.
