Component Cross Reference
I have part 50MH71MEFC4X7 that is a dielectric 1uF 50V capacitor however the lead pitch is too narrow. I need 2.5mm (0.1in) lead spacing. I am hoping to find the correct capacitor in on tape and reel.
When I select 2.5mm lead spacing the capacitors I get back are all 12mm tall or taller. Here’s an example:
UVZ1H010MDD1TD Nichicon | Capacitors | DigiKey
We do have a couple available for ordering but as we are currently out of stock standard lead times and minimum order quantities will apply.
1 µF Aluminum Electrolytic Capacitors | Electronic Components Distributor DigiKey
Please review the datasheets to ensure the alternative will work for your application.
