Compustar Automotive Alarms Connectors
Hi guys!
I’m trying to find the connectors used in their alarm systems, but couldn’t find them. The blue one is used a lot in several different colours and pins configurations (from 2 way to 6 way).
Thanks in advance!
Do you have the distance between each socket position (horizontally and vertically)? Having a center to center distance does help. They appear to be 2.54mm from a glance. I’m not sure about the ID of either connector here. I looked in our rectangular housings and assemblies but nothing looked similar with the latch on the top.
Did you work it out OP? I’ve tried many hirose terminals but have not figured it out yet!
