The ball float project is a demonstration of industrial control systems with an emphasis on IO-link. It features a Siemens S7-1200 PLC with a PROFINET connection to a SICK IO-Link master which is then connected to three IO-Link enabled devices. Together these elements form an interactive display where the user can adjust the height of a ping pong ball floating in a tube as shown in Figure 1.
Difficulty:
Student— difficulty levels explained
Last update: 15 Jun 2026
Figure 1: Image of the ball float project on an A-frame.
Project Highlights
The section provides a high-level introduction to the technology featured on the DigiKey demo.
- The user interacts with the project using slide control to control the position of the ball within the tube. The screen capture for the HMI is shown in Figure 2.
- A fan is used to provide a column of air for the ball. This fan is driven by a Pulse Width Modulation signal from the PLC.
- The IO-Link driven LED strip highlights the ball position.
- The user can enter can enter text messages into the Siemens HMI to be displayed on the top mounted text display.
Figure 2: Image of the HMI control window.
Control Algorithm
This project implements a classic Proportional Derivative Integral (PID) control system.
- The user provides the desired setpoint via the HMI.
- The distance sensor provides the feedback indicating ball height in the tube.
- A Siemens designed PID performs the internal calculation
- The PID drive is sent to the fan which controls ball height.
- Automatic tuning was used to set the PID control parameters.
- The HMI displays the input, feedback, and plant drive signals.
Networking
IO-Link is used to connect the text display, the distance sensor, and the LED strip. These are connected to the IO link master as ports S2, S4, and S6 respectively
The PROFINET protocol is used to communicate between the PLC, HMI, and IO Link master. A unmanaged switch is used for the Ethernet connections.
Featured DigiKey Products
These products define the core architecture of the IO-Link Ball Float demonstration and illustrate how a modern PLC-based system senses, communicates, and responds in real time.
Siemens S7-1200 PLC Gen 2 PLC (CPU 1214C): The PLC serves as the central controller for the demonstration. It hosts the PID logic, exchanges data over PROFINET, and coordinates the HMI and IO-Link devices.
- Latest addition to Siemens S7-1200 family.
- Expandable with local modules, IO-Link, and distributed I/O such as the ET 200SP
- Note the quick disconnect terminal blocks for local I/O
- Native PROFINET
- Near Field Communication allowing a cell phone to read diagnostic data
SICK SIG300 IO-Link master (PROFINET): The SIG300 forms the bridge between the PLC and the smart field devices. It is the key networking element that allows the demo to showcase practical IO-Link integration.
- PROFINET to IO-Link
- Three styles of ports including 2-wire Class-A1, 3 wire Class-A2, and high current Class-B (up to 4 A per M12 connector).
- USB programmed or controlled from PLC
- IP67
SICK W10 Distance Sensor: This sensor provides the feedback signal for the control loop by measuring the ball position within the tube.
- IO-Link enabled
- Red laser pointer
- 50 to 250 mm distance detection
- Cyclic data transfer to the PLC via the SIG300
Banner SD50 Status Display: The SD50 gives the demo an operator-facing output, allowing text and status information to be displayed directly from the control system.
- IO-Link enabled
- Cyclic update
- Change text on the fly
E-T-A Solid State Circuit Breaker: The electronics circuit breaker protects the demo’s 24 VDC control system while giving the project a visible, industrial-grade layer of electronic protection.
- Semiconductor-based current limiting
- Near instantaneous response (no thermal or magnetic delay)
- Slide switch adjustable current limit
- LED status display
Supporting DigiKey TechForum Material
Learn more about the technology by exploring these closely related articles.
Thermal PID on a Siemens S7-1200: This engineering brief introduces the Siemens PID Technical Object (TO). A simple thermal system is used to demonstrate the configuration and automatic tuning.
Required Files for IO-Link: Explore the system-level configuration of IO-Link using the Siemens PLC, SICK IO-Link master, and SICK W10 distance sensor.
Getting Started with the Banner’s SD50 Status Display with IO-Link: Initial configuration for the Banner SD50 IO-Link
How to Clear SIG300 Errors: This checklist identifies many of the lessons learned when integrating IO-Link master.
Misconceptions in Industrial IO-Link Setup: Explore common misconception revolving around the M12 connectors and general IO-Link hardware.
Parts List
Project components available from DigiKey:
Transit block
87141882 - KDL/H-VA-FDA 24/12 STAINLESS HOUSING - Murrplastik Systems, Inc.
87141716 - FRAME GROMMET SPLIT TPE BLUE - Murrplastik Systems, Inc.
87141770 - FRAME GROMMET SPLIT TPE BLUE - Murrplastik Systems, Inc.
Ethernet switch
Cables
T4171010005-002 - CIRC CBL 5POS PLUG TO WIRE 1.64’ - TE Connectivity AMP Connectors
TAD14145101-001 - CIRC CBL 4POS RCPT TO WIRE 1.64’ - TE Connectivity AMP Connectors
1552200064 - CABLE 4COND 22AWG BLACK METER - Molex
1425009 - CIRC CBL 5POS RCPT TO PLUG 0.98’ - Phoenix Contact
1329935 - CIRC CBL 5POS PLUG TO WIRE 3.28’ - Phoenix Contact
1699850 - CIRC CBL 4POS RCPT TO PLUG 3.28’ - Phoenix Contact
1414772 - CIRC CBL 5POS PLUG TO WIRE 4.92’ - Phoenix Contact
1513910 - CIRC CBL 5POS RCPT TO PLUG 6.56’ - Phoenix Contact
2106182 - PUR/2*2*0,34/GN/SH - SICK, Inc.
09454521509 - CABLE MOD 8P8C JACK-PLUG 3.28’ - HARTING
1251610010 - CABLE MOD 8P8C PLUG-PLUG 3.28’ - Weidmüller
Additional Supporting Parts
9GA0424P3J0011 - FAN AXIAL 40X28MM 24VDC WIRE - Sanyo Denki America Inc.
1827729 - TERM BLOCK PLUG 4POS 3.81MM - Phoenix Contact
1551671 - CONN ADAPTER 5P-5P F-M PNL MNT - Phoenix Contact
1829361 - TERM BLK 4POS GREEN - Phoenix Contact
1404983 - NUT JAM STEEL M16X1.5 - Phoenix Contact
3211431 - COMPONENT TERMINAL BLOCK CROSS - Phoenix Contact
