How to Clear PLC to SICK SIG300 Errors
Start with this checklist if the PLC has a blinking red error lamp and you suspect an IO-Link fault.
  • Verify that access rights for each port are returned to PLC control.
  • All field devices are connected to the IO Link master(s).
  • Each field device is connected to the assigned channel.
  • TIA Portal’s IO-Link master submodules are properly assigned.
Note: Log into the SIG300 using a USB cable and then point a browser to 169.254.0.1.
Figure 1: Hardware used for the IO-Link troubleshooting along with a Siemens comms error.
Access Rights Errors in the IO-Link Master
Incorrectly configured access rights are a painful source of self-induced errors. As part of troubleshooting we log into the IO-Link master, change the port to local control and then forget to return control back to the PLC.
For example, consider the SICK SIG300 Profinet IO-Link Master. The access rights are shown in Figure 2. The last four boxes in the first column must be selected for unrestricted PLC access.
Figure 2: Image of the SICK SIG300 IO-Link Master port access rights configuration.
Tech Tip: The access rights are assigned on an individual port basis! Check them all.
Physical connection Errors in the IO-Link Master
Unlike a simple Ethernet switch, IO-Link ports are not generic. Instead, each port is dedicated to a specific field device. This is no different than the physical connections to rack and slot IO such as the ET 200SP with each wire connecting to a specific I/O pin.
In the fog of 3 AM troubleshooting it is very easy to:
  • Swap sensors
  • Leave a sensor disconnected
  • Fail to tighten an M12 connector leading to intermittent connections
Software Configuration Errors
From TIA Portal, the IO-Link master is handled using a rack and slot configuration. This is shown in Figure 3, where we see the top-level SICK SIG300 representation (left). The “modules” are shown in the device overview (right). For this configuration:
  • Port S1 is configured as a digital output
  • Port S2 is dedicated to the Banner SD50 display
  • Port S3 unused
  • Port S4 is dedicated to the SICK W10 distance sensor
  • Ports S5 to S8 are unused
Note that each port is mapped to a specific (fixed) memory address within the PLC. This is why the IO-Link field devices connectors cannot be swapped. The PLC would respond with gibberish if, for example, the W10 and the SD50 were swapped.
Figure 3: Configuration of the SICK SIG300 from within Siemens TIA Portal.
Parting Thoughts
Leave a comment if you encounter a problem with your IO-Link system.
  • What were the symptoms?
  • How did you solve the problem?
  • What were the dead ends that consumed time?
Best wishes,
About This Author
