Q) How do I export a schematic?
A) On the top task bar select [Export]. Then select the appropriate file type to export the schematic.
- Click export on the task bar
- Select the type of file you want to export it as
- Save the file of the schematic
Q) How can I export (pdf) with the gridlines?
A) You cannot export them to a pdf, the gridlines will always disappear.
Q) Is there a way to export the file from the Scheme-It to a MS Visio format?
A) Scheme-It does not have an option for MS Visio format.
Q) I want to import schematic into PCBWeb?
A) Schematic cannot be imported from Scheme-It to PCBWeb. User would need to rebuild the schematic in PCBWeb. You can export it to PCBWeb via a SCHBOM file after clicking export on the task bar. See Above
Q) I am using Scheme-It, is there an option for CAD?
A) Scheme-It is unable to export to CAD, can only export to .png, .svg, pdf, or an SCHBOM file for PCBWeb.
