------Question for 60010009013 Please Put your question below------
Is there any part number which meets the same specs M2.5 Screw, 2-56 Socket Length - Below Head 0.177" (4.50mm)
I have a connector which the cable is 2-56 threads but needs the next standoff or Jackscrew to be able to mate. Figured there had to be something out there but I have came up with zero results. May have to resort to threading the matted connector to a different thread if there truly isnt any compatible hardware.
Hello C-Karakla,
Thank you for using the DigiKey Tech forum.
I am sorry to inform you there is not a good cross for part number 60010009013.
