Help identifying a motorola mosfet /transistor
Continuing the discussion from Help identifying a motorola mosfet /transistor:
The Motorola mosfet /transistor in inside the circle it says NL72
Where is this board installed?
Is this the EBS for the car?
I could not come up with a good part number for the NLEA028
Kelsey Hayes ABS module out of a 2001 gmc
I really don’t care if I find a exact replacement I’m pretty sure that it’s discontinued and obsolete I just need to replace it I know it’s bad I’ve tested it every which way and it is bad here’s a couple of extra pictures if it may help I have plenty of mosfets transistors also in the middle of the little circle it says NL72.
Lukwarm,
I found nothing for these numbers, to identity this part.
It may be a proprietary part, and that’s why the numbers are not matching anything.
Unfortunately, we would need a full description with type, pinout, Voltage, current,… to try and find a match. You can do some trial and error with your other Mosfets, but you could damage other parts of the board trying to get it to work.
