I have an Electric Motor (Hub Motor) that is off an electric scooter I own. The motor started to act strange and I started to diagnose the issue and found that one of the Hall Effect Sensors was stuck at 3.31V and would not change when I moved the magnets around it like the others.
The issue Is, I’m unable to find any markings on the sensor that could help identify the sensor, so I can replace it. I’m not skilled enough to know what I can buy and use instead of this and hope someone will know the answer.
Known information :
Red cable + - 5.15V
The sensor operates @ 0.1v to 3.31V - It moves from this to this when you rotate the magnets
