ID a freehanging connector
I need help identifying a product number for a free hanging connector.
globalhandpiece
Thank you for contacting DigiKey , It is hard to tell from the pictures without knowing the pitch and row spacing take a look at part number WM3363-ND , check data sheets to see if this is the correct connector .
Thanks Craig
Hello globalhandpiece,
Without dimensions and pin spacing, we can only look for the best match.
732-4352-ND appears to be a match for your freehanging connector.
If you wanted a freehanging mating connector, we do not have one. The only option would be to solder wires to the through hole mating connector. The only one we have in stock, is the right angle version 732-4324-ND.
Please check the datatsheets to verify a match to your application.
