Says it’s a Defond DMC-1112, NC the other side looks like it’s dmc-1115 which is molded on the plastic. Can’t find the same switch in search so I’m looking for a replacement. It’s a pressure switch for a marine fresh water pump if it matters.
Hi,
Welcome to the Digikey tech forum. Take a look at these limit switches to see if one will work for your application.
Here’s the Defond web page listing all their limit switches.
If you can figure out which one you have we can probably find an equivalent part from a manufacturer that Digi-Key stocks.
