hi there looking to replace this defond switch with an equivalent replacement. On the switch I can read the following t125 8A 125VAC, 8(3) 250 VAC. I’ve attached a picture for reference. Please let me know suggestions. Thank you!
Thanks I’ll take a look as the switch currently has 6 pins and is connected to a LED driver
I was able to find the part number for the actual switch not sure if there is a better match LF24A3000W.
I found this option with is close dimensionally, Digikey part CKN11126-ND The actuator style is different and would not be as handy if your switching back and forth frequently but it’s something to look at.
