I’m looking at replacing a panel amperage reader with a MA12-110V-CU. While looking through all the information available on this display I cannot find what current transducers I’m supposed to use with it. Can you let me know what current transducer I should use? I want to read a pumps amperage that is around 25 amps.
Also, there doesn’t seem to be any information on how to setup the control for different amperage ranges. But the instructions do not make it clear how to set this up. Can I buy any CT any just add the CTs ranges and it will display? It is very unclear.
Thanks
-JC
@JCondron
I too am not seeing that they list a specific series that I can tell.
However the spec for the MA12-110V-CU read that the input for the meter can handle a max of 5A.
So any CT that would produce no more than 5A at the highest expected measured value would work.
So maybe the 2543-189SFT-025-ND.
189SFT-025 Sifam Tinsley Instrumentation Inc | Current Sense Transformers | DigiKey Marketplace
Looks like the controller itself can handle only 5amp going through it. But with an external CT it can read 5 to 4000 A. But what does the CTs signal need to be? How do you program it, there doesn’t appear to be buttons. “In steps” what are the steps?
https://www.selec.com/product-details/digital-panel-meter-ma12
Thanks
(attachments)
Hello @JCondron,
As an example, consider this Selec SPCT series CT
The datasheet describes a “current ratio.” In this particular case, a 250 A (AC) current passing through a busbar passing through the CT’s aperture will result in a 5 A 9AC) current on the CT’s output.
Note that many different products are available in the Selec SPCT series to cover between 60 A and 1200 A. We select the CT suitable to the end application and then scale (program) the display accordingly. Note that the CT’s in this family produce 5 A at their specified rated primary current.
If it helps, we could call the Selec SPCT a family of 5 A CTs.
Best wishes,
Excellent. That makes sense. Thanks for the response. I wish the controllers programming manual was available before I order. I would have liked to read it before I order. But it will likely come with the product and I’ll read it then.
Thanks
-JC
Hi @JCondron,
Recommend looking deeper into the Selec documentation.
As a rule, the “in the box” documentation is also available on the web.
Sincerely,
Aaron
