Hi there, I need some help identifying connectors that will mate with x203/204 and x206.
I found the T4011008031-000 for the cable connector.
T4011008031-000 TE Connectivity AMP Connectors | Connectors, Interconnects | DigiKey
For the Panel connector I found the T4041037031-000 for reference.
T4041037031-000 TE Connectivity AMP Connectors | Connectors, Interconnects | DigiKey
Ok great, thank you! Any luck identifying a connector for x206?
Hello cfs5947,
The size of the X203 & X204 appear to be about the M8 size.
Click here for some possible matches to these connectors.
The X206 appears to be a M12 size, and the only option I found with the right center polarization, is 277-16278-ND.
Please check the datasheets to verify compatibility to your application.
Thanks everyone!!! I’m all set.
