P12875-ND running on 208
Hi,
Will the nominally rated 230 VAC P12875-ND axial fan run on 208 VAC? I could not see anything in the datasheet.
Thanks,
Chris
Hello Chris, thank you for your inquiry.
That fan may work to some capacity on 208VAC, but I would recommend using it at the rated 230VAC for best results.
do you have any 208 fans?
never mind, Brock. I can use one of your many 120VAC fans. Thanks for responding.
Best Regards,
Chris
