In battery management systems, there are a few ways to manipulate the configuration of your batteries to achieve different outcomes or to achieve specific performance goals — most commonly seen are series or parallel configurations.
What Is Parallel Battery Charging?
Parallel battery charging is one of the basic battery configurations used in battery management systems. In this setup, batteries are placed in a parallel configuration, which results in a higher capacity, but maintains the same voltage. This differs from a series configuration, which provides a higher voltage, but the same battery capacity, which usually applies to higher power products
Why Use Parallel Battery Charging?
As longer battery life becomes an ever more critical factor for consumer devices, manufacturers are getting creative with how to extend a battery pack’s useful capacity. One of the simplest ways to do this is by using parallel charging.
Parallel charging batteries allow the user to charge multiple batteries at once, which provides longer battery life and increased reliability.
Example: To implement intelligent and safe parallel charging, Analog Devices offers battery fuel gauges like the MAX17330 which combine accurate state-of-charge monitoring with protection and balancing features.
Series vs. Parallel: What’s the Difference?
| Configuration | Voltage | Capacity | Use Case |
| Series | Adds up (more voltage) | Same as one cell | High voltage devices |
| Parallel | Same as one cell | Adds up | High-capacity devices |
What’s Next?
Now that we are familiar with the fundamentals of parallel battery charging, you might be wondering — how do we charge all those batteries quickly and efficiently?
That’s where USB-C comes in.
Check out our next article on "USB-C’s Integration into the Modern Parallel Battery Charging ", and “Real-World Applications and Design Tips” to see it all come together.
Related Article
Implementing USB-C Parallel Charging Systems with MAX17330
How USB-C Integration Enhances Parallel Battery Charging?
Get Started with USB-C Power Delivery
Applicable Part Numbers
| 175-MAX17262HEWL+TTR-ND,175-MAX17262HEWL+TCT-ND,175-MAX17262HEWL+TDKR-ND | MAX17262HEWL+T |
| 175-MAX17260SEWL+TTR-ND,175-MAX17260SEWL+TCT-ND,175-MAX17260SEWL+TDKR-ND | MAX17260SEWL+T |
| 175-MAX17262REWL+TTR-ND,175-MAX17262REWL+TCT-ND,175-MAX17262REWL+TDKR-ND | MAX17262REWL+T |
| 505-MAX17260SETD±ND | MAX17260SETD+ |
| 175-MAX17260SETD+TTR-ND,175-MAX17260SETD+TCT-ND,175-MAX17260SETD+TDKR-ND | MAX17260SETD+T |
| MAX17048G+T10TR-ND,MAX17048G+T10CT-ND,MAX17048G+T10DKR-ND | MAX17048G+T10 |
| MAX17055EWL+TTR-ND,MAX17055EWL+TCT-ND,MAX17055EWL+TDKR-ND | MAX17055EWL+T |
| MAX17055ETB+TTR-ND,MAX17055ETB+TCT-ND,MAX17055ETB+TDKR-ND | MAX17055ETB+T |
| 175-MAX17303X+TTR-ND,175-MAX17303X+TCT-ND,175-MAX17303X+TDKR-ND | MAX17303X+T |
| MAX17201G+TTR-ND,MAX17201G+TCT-ND,MAX17201G+TDKR-ND | MAX17201G+T |
| 175-MAX17261METD+TTR-ND,175-MAX17261METD+TCT-ND,175-MAX17261METD+TDKR-ND | MAX17261METD+T |
| MAX17261METD±ND | MAX17261METD+ |
| MAX6778XK+TTR-ND,MAX6778XK+TCT-ND,MAX6778XK+TDKR-ND | MAX6778XK+T |
| MAX17201G±ND | MAX17201G+ |
| MAX17205G+00E-ND | MAX17205G+00E |
| MAX17205G+TTR-ND,MAX17205G+TCT-ND,MAX17205G+TDKR-ND | MAX17205G+T |
| 175-MAX17330X22+TTR-ND,175-MAX17330X22+TCT-ND,175-MAX17330X22+TDKR-ND | MAX17330X22+T |
| DS2745U+TR-ND,DS2745U+CT-ND,DS2745U+DKR-ND | DS2745U+T&R |
| 175-DS2786G+T&RTR-ND,175-DS2786G+T&RCT-ND,175-DS2786G+T&RDKR-ND | DS2786G+T&R |
| 175-DS2782E+T&RTR-ND,175-DS2782E+T&RCT-ND,175-DS2782E+T&RDKR-ND | DS2782E+T&R |
| 175-MAX38888ATD+TTR-ND,175-MAX38888ATD+TCT-ND,175-MAX38888ATD+TDKR-ND | MAX38888ATD+T |
| DS2438Z+T&RTR-ND,DS2438Z+T&RCT-ND,DS2438Z+T&RDKR-ND | DS2438Z+T&R |
| 175-DS2788E+T&RTR-ND,175-DS2788E+T&RCT-ND,175-DS2788E+T&RDKR-ND | DS2788E+T&R |
| DS2788E±ND | DS2788E+ |
| DS2777G±ND | DS2777G+ |
| 175-MAX14680EWC+TTR-ND,175-MAX14680EWC+TCT-ND,MAX14680EWC+TCT-ND,175-MAX14680EWC+TDKR-ND | MAX14680EWC+T |
| 175-MAX17048X+T10TR-ND,175-MAX17048X+T10CT-ND,175-MAX17048X+T10DKR-ND | MAX17048X+T10 |
| 175-MAX17260BEWL+TTR-ND,175-MAX17260BEWL+TCT-ND,175-MAX17260BEWL+TDKR-ND | MAX17260BEWL+T |
| MAX6776XKC+TR-ND,MAX6776XKC+CT-ND,MAX6776XKC+DKR-ND | MAX6776XKC+T |
| MAX6775XKB+TTR-ND,MAX6775XKB+TCT-ND,MAX6775XKB+TDKR-ND | MAX6775XKB+T |
| 505-MAX17303G±ND | MAX17303G+ |
| MAX17201G+00E-ND | MAX17201G+00E |
| MAX6777XK+TR-ND,MAX6777XK+CT-ND,MAX6777XK+DKR-ND | MAX6777XK+T |
| 505-MAX17320G20±ND | MAX17320G20+ |
| 505-MAX17320G22±ND | MAX17320G22+ |
| MAX17205G±ND | MAX17205G+ |
| 175-MAX17301X+TTR-ND,175-MAX17301X+TCT-ND,175-MAX17301X+TDKR-ND | MAX17301X+T |
| DS2745U±ND | DS2745U+ |
| DS2782G±ND | DS2782G+ |
| 175-DS2756E+T&RTR-ND,175-DS2756E+T&RCT-ND,175-DS2756E+T&RDKR-ND | DS2756E+T&R |
| DS2756E±ND | DS2756E+ |
| DS2438AZ+TR-ND,DS2438AZ+CT-ND,DS2438AZ+DKR-ND | DS2438AZ+T&R |
| DS2438Z±ND | DS2438Z+ |
| 505-MAX17841BGUE/V±ND | MAX17841BGUE/V+ |
| DS2782E±ND | DS2782E+ |
| DS2764AE±ND | DS2764AE+ |
| DS2780E±ND | DS2780E+ |
| 175-DS2762AE+T&RTR-ND,175-DS2762AE+T&RCT-ND,175-DS2762AE+T&RDKR-ND | DS2762AE+T&R |
| MAX20303BEWN+TTR-ND,MAX20303BEWN+TCT-ND,MAX20303BEWN+TDKR-ND | MAX20303BEWN+T |
| MAX17843ACB/V±ND | MAX17843ACB/V+ |
| 175-MAX14634EWC+TTR-ND,175-MAX14634EWC+TCT-ND,175-MAX14634EWC+TDKR-ND | MAX14634EWC+T |
| MAX16915AUB±ND | MAX16915AUB+ |
| MAX16914AUB±ND | MAX16914AUB+ |
| 175-MAX17261MEWL+TTR-ND,175-MAX17261MEWL+TCT-ND,175-MAX17261MEWL+TDKR-ND | MAX17261MEWL+T |
| 175-MAX17201X+TTR-ND,175-MAX17201X+TCT-ND,175-MAX17201X+TDKR-ND | MAX17201X+T |
| MAX17215G+00E-ND | MAX17215G+00E |
| 175-MAX17320X20+TTR-ND,175-MAX17320X20+TCT-ND,175-MAX17320X20+TDKR-ND | MAX17320X20+T |
| MAX6775XKC+TTR-ND,MAX6775XKC+TCT-ND,MAX6775XKC+TDKR-ND | MAX6775XKC+T |
| 175-MAX6775XKA+TTR-ND,175-MAX6775XKA+TCT-ND,175-MAX6775XKA+TDKR-ND | MAX6775XKA+T |
| DS2786BG±ND | DS2786BG+ |
| 505-MAX17320G10±ND | MAX17320G10+ |
| 175-MAX6433UK+TTR-ND,175-MAX6433UK+TCT-ND,175-MAX6433UK+TDKR-ND | MAX6433UK+T |
| DS2746G±ND | DS2746G+ |
| MAX14653EWC+TTR-ND,MAX14653EWC+TCT-ND,MAX14653EWC+TDKR-ND | MAX14653EWC+T |
| 505-MAX17320G12±ND | MAX17320G12+ |
| DS2786G±ND | DS2786G+ |
| DS2781E+TR-ND,DS2781E+CT-ND,DS2781E+DKR-ND | DS2781E+T&R |
| DS2781G±ND | DS2781G+ |
| DS2438AZ±ND | DS2438AZ+ |
| DS2764BE±ND | DS2764BE+ |
| DS2778G±ND | DS2778G+ |
| DS2776G±ND | DS2776G+ |
| DS2781E±ND | DS2781E+ |
| DS2762BE±ND | DS2762BE+ |
| DS2762AE±ND | DS2762AE+ |
| MAX14920ECB±ND | MAX14920ECB+ |
| MAX14921ECS±ND | MAX14921ECS+ |
| 505-MAX17823BGCB/V±ND | MAX17823BGCB/V+ |
| 175-MAX14921ECS+TTR-ND,175-MAX14921ECS+TCT-ND,175-MAX14921ECS+TDKR-ND | MAX14921ECS+T |
| 175-MAX14670EWL+TTR-ND,175-MAX14670EWL+TCT-ND,175-MAX14670EWL+TDKR-ND | MAX14670EWL+T |
| MAX14606EWL+TTR-ND,MAX14606EWL+TCT-ND,MAX14606EWL+TDKR-ND | MAX14606EWL+T |
| 175-MAX6776XKB+TTR-ND,175-MAX6776XKB+TCT-ND,175-MAX6776XKB+TDKR-ND | MAX6776XKB+T |
| 175-MAX6776XKA+TTR-ND,175-MAX6776XKA+TCT-ND,175-MAX6776XKA+TDKR-ND | MAX6776XKA+T |
| MAX6775LTA+TTR-ND,MAX6775LTA+TCT-ND,MAX6775LTA+TDKR-ND,2156-MAX6775LTA+T-ND | MAX6775LTA+T |
| MAX17211G+00E-ND | MAX17211G+00E |
| MAX6436UT+TTR-ND,MAX6436UT+TCT-ND,MAX6436UT+TDKR-ND | MAX6436UT+T |
| 175-MAX6434UK+TTR-ND,175-MAX6434UK+TCT-ND,175-MAX6434UK+TDKR-ND | MAX6434UK+T |
| 175-MAX17215G+TTR-ND,175-MAX17215G+TCT-ND,175-MAX17215G+TDKR-ND | MAX17215G+T |
| DS2782G+TR-ND,DS2782G+CT-ND,DS2782G+DKR-ND | DS2782G+T&R |
| MAX1538ETI+TR-ND,MAX1538ETI+CT-ND,MAX1538ETI+DKR-ND | MAX1538ETI+T |
| 175-MAX17841BGUE/V+TTR-ND,175-MAX17841BGUE/V+TCT-ND,175-MAX17841BGUE/V+TDKR-ND | MAX17841BGUE/V+T |
| MAX1538ETI±ND | MAX1538ETI+ |
| DS2780G±ND | DS2780G+ |
| MAX1259CWE±ND | MAX1259CWE+ |
| 175-MAX14920ECB+TTR-ND,175-MAX14920ECB+TCT-ND,175-MAX14920ECB+TDKR-ND | MAX14920ECB+T |
| 505-MAX17853ACB/V±ND | MAX17853ACB/V+ |
| 175-MAX17823BGCB/V+TTR-ND,175-MAX17823BGCB/V+TCT-ND,175-MAX17823BGCB/V+TDKR-ND | MAX17823BGCB/V+T |
| 505-MAX17300G±ND | MAX17300G+ |
| 505-MAX17310G±ND | MAX17310G+ |
| MAX17215G±ND | MAX17215G+ |
| 175-MAX77972EWX+TTR-ND,175-MAX77972EWX+TCT-ND,175-MAX77972EWX+TDKR-ND | MAX77972EWX+T |
| 175-MAX14525ETA+TTR-ND,175-MAX14525ETA+TCT-ND,175-MAX14525ETA+TDKR-ND | MAX14525ETA+T |
| 505-MAX20095ATIA/VY±ND | MAX20095ATIA/VY+ |
| 505-MAX17330X22±ND | MAX17330X22+ |
| 505-MAX17301G±ND | MAX17301G+ |
| 505-MAX17841BGUE±ND | MAX17841BGUE+ |
| 505-ADES1756GCB/V±ND | ADES1756GCB/V+ |
| 505-MAX1259CPE±ND | MAX1259CPE+ |
| 505-ADES1755GCB/V±ND | ADES1755GCB/V+ |
| 505-ADES1754GCB/V±ND | ADES1754GCB/V+ |
| 505-MAX17823BGCB±ND | MAX17823BGCB+ |
| MAX17830GUN±ND | MAX17830GUN+ |
| MAX17830GUN/V±ND | MAX17830GUN/V+ |
| 175-MAX17830GUN/V+TTR-ND,175-MAX17830GUN/V+TCT-ND,175-MAX17830GUN/V+TDKR-ND | MAX17830GUN/V+T |
| 2156-MAX1707ETG±ND | MAX1707ETG+ |
| 2156-MAX6787TA±ND | MAX6787TA+ |
| 2156-MAX1786EUI±ND | MAX1786EUI+ |
| 2156-MAX17130ETL±ND | MAX17130ETL+ |
| 2156-MAX1786AEUI+T-ND | MAX1786AEUI+T |
| 2156-MAX8629ETI+T-ND | MAX8629ETI+T |
| 2156-MAX8618ETL±ND | MAX8618ETL+ |
| 2156-MAX8617ETL±ND | MAX8617ETL+ |
| 2156-MAX6781LTC±ND | MAX6781LTC+ |
| 2156-MAX1906VEGE-ND | MAX1906VEGE |
| 2156-MAX1906SEGE-ND | MAX1906SEGE |
| 2156-MAX6789TB±ND | MAX6789TB+ |
| 2156-MAX6790TB±ND | MAX6790TB+ |
| 2156-MAX4921BETD±ND | MAX4921BETD+ |
| 2156-MAX4920BETD±ND | MAX4920BETD+ |
| 2156-MAX6428ORUR±ND | MAX6428ORUR+ |
| 2156-MAX6428MQUR±ND | MAX6428MQUR+ |
| 2156-MAX6427DHUR-ND | MAX6427DHUR |
| 2156-MAX6436UT-T-ND | MAX6436UT-T |
| 2156-MAX6438UT-T-ND | MAX6438UT-T |
| 2156-MAX6431EHUS-T-ND | MAX6431EHUS-T |
| 2156-MAX6431FJUS-T-ND | MAX6431FJUS-T |
| 2156-MAX6432EIUS-T-ND | MAX6432EIUS-T |
| 2156-MAX6431CIUS-T-ND | MAX6431CIUS-T |
| 2156-MAX6431DHUS-T-ND | MAX6431DHUS-T |
| 2156-MAX6431CHUS-T-ND | MAX6431CHUS-T |
| 2156-MAX6432DHUS-T-ND | MAX6432DHUS-T |
| 2156-MAX6430ORUS-T-ND | MAX6430ORUS-T |
| 2156-MAX6432FJUS-T-ND | MAX6432FJUS-T |
| 2156-MAX6430EGUS-T-ND | MAX6430EGUS-T |
| 2156-MAX6432MRUS-T-ND | MAX6432MRUS-T |
| 2156-MAX6432EHUS-T-ND | MAX6432EHUS-T |
| 2156-MAX6430PQUS-T-ND | MAX6430PQUS-T |
| 2156-MAX6432ORUS-T-ND | MAX6432ORUS-T |
| 2156-MAX8629CETI±ND | MAX8629CETI+ |
| 2156-MAX1829ETL±ND | MAX1829ETL+ |
| 2156-MAX6429DHUR-T-ND | MAX6429DHUR-T |
| 2156-MAX6429MRUR-T-ND | MAX6429MRUR-T |
| 2156-MAX6427EHUR-T-ND | MAX6427EHUR-T |
| 2156-MAX6428AGUR-T-ND | MAX6428AGUR-T |
| 2156-MAX6429KTUR-T-ND | MAX6429KTUR-T |
| 2156-MAX6428MRUR-T-ND | MAX6428MRUR-T |
| 2156-MAX6427KQUR-T-ND | MAX6427KQUR-T |
| 2156-MAX6429EHUR-T-ND | MAX6429EHUR-T |
| 2156-MAX6429ORUR-T-ND | MAX6429ORUR-T |
| 2156-MAX6429EIUR-T-ND | MAX6429EIUR-T |
| 2156-MAX6786TA±ND | MAX6786TA+ |
| 2156-MAX6788TA±ND | MAX6788TA+ |
| 2156-MAX6847KASD3-ND | MAX6847KASD3 |
| 2156-MAX6440UTEHRD3-ND | MAX6440UTEHRD3 |
| 2156-MAX6847KARD3-T-ND | MAX6847KARD3-T |
| 2156-MAX6440UTEHRD3-T-ND | MAX6440UTEHRD3-T |
| 2156-MAX6847KASD3-T-ND | MAX6847KASD3-T |
| 2156-MAX6846KAWD3-T-ND | MAX6846KAWD3-T |
| 2156-MAX6440UTFJTD7-T-ND | MAX6440UTFJTD7-T |
| 2156-MAX6440UTKQSD3-T-ND | MAX6440UTKQSD3-T |
| 2156-MAX6439UTDHSD3-T-ND | MAX6439UTDHSD3-T |
| 2156-MAX17817EUI+T-ND | MAX17817EUI+T |
| 2156-MAX6849KAVD7-T-ND | MAX6849KAVD7-T |
| 2156-MAX6848KARD7-T-ND | MAX6848KARD7-T |
| 2156-MAX6849KASD3-T-ND | MAX6849KASD3-T |
| 2156-MAX6848KATD3-T-ND | MAX6848KATD3-T |
| 2156-MAX1827ETL-ND | MAX1827ETL |
| 2156-MAX1827ETL±ND | MAX1827ETL+ |
| 2156-MAX6848KATD3-ND | MAX6848KATD3 |
| 505-MAX6775LTB+TTR-ND,2156-MAX6775LTB+T-ND | MAX6775LTB+T |
| 2156-MAX8568BETE-ND | MAX8568BETE |
| 2156-MAX6775LTA±ND | MAX6775LTA+ |
| 2156-MAX6442KAEISD3-T-ND | MAX6442KAEISD3-T |
| 2156-MAX6441KAEISD3-T-ND | MAX6441KAEISD3-T |
| 2156-MAX6441KAEHRD3-T-ND | MAX6441KAEHRD3-T |
| 2156-MAX6441KAKQVD3-T-ND | MAX6441KAKQVD3-T |
| 2156-DS2746G-C02+TR-ND | DS2746G-C02+TR |
| 2156-MAX1526ETM+G104-ND | MAX1526ETM+G104 |
| 2156-MAX1906XEGE-ND | MAX1906XEGE |
| 2156-MAX6428AGUR-ND | MAX6428AGUR |
| 2156-MAX6431FJUS-ND | MAX6431FJUS |
| 2156-MAX6432MRUS-ND | MAX6432MRUS |
| 2156-MAX6431MRUS-ND | MAX6431MRUS |
| 2156-MAX6432DHUS-ND | MAX6432DHUS |
| 2156-MAX6429MRUR-ND | MAX6429MRUR |
| 2156-MAX6439UTDHSD3-ND | MAX6439UTDHSD3 |
| 2156-MAX6429KTUR-ND | MAX6429KTUR |
| 2156-MAX6432EHUS-ND | MAX6432EHUS |
| 2156-MAX6441KAEISD3-ND | MAX6441KAEISD3 |
| 2156-MAX6432FJUS-ND | MAX6432FJUS |
| 2156-MAX6432ORUS-ND | MAX6432ORUS |
| 2156-MAX6430PQUS-ND | MAX6430PQUS |
| 2156-MAX6430EIUS-ND | MAX6430EIUS |
| 2156-MAX6431CIUS-ND | MAX6431CIUS |
| 2156-MAX6430DHUS-ND | MAX6430DHUS |
| 2156-MAX6846KAWD3-ND | MAX6846KAWD3 |
| 2156-MAX6430EHUS-ND | MAX6430EHUS |
| 2156-MAX6431EIUS±ND | MAX6431EIUS+ |
| 2156-MAX6431EHUS-ND | MAX6431EHUS |
| 2156-MAX6429ORUR-ND | MAX6429ORUR |
| 2156-MAX6428ORUR-ND | MAX6428ORUR |
| 2156-MAX6431ORUS-ND | MAX6431ORUS |
| 2156-MAX6429DHUR-ND | MAX6429DHUR |
| 2156-MAX6427EIUR-ND | MAX6427EIUR |
| 2156-MAX6435UK-ND | MAX6435UK |
| 2156-MAX6428EHUR-ND | MAX6428EHUR |
| 2156-MAX6432EIUS-ND | MAX6432EIUS |
| 2156-MAX6431CHUS-ND | MAX6431CHUS |
| 2156-MAX6440UTFJTD7-ND | MAX6440UTFJTD7 |
| 2156-MAX6848KARD7-ND | MAX6848KARD7 |
| 2156-MAX6431EIUS-ND | MAX6431EIUS |
| 2156-MAX6429EHUR-ND | MAX6429EHUR |
| 2156-MAX6442KAKQSD3-ND | MAX6442KAKQSD3 |
| 2156-MAX6849KAVD7-ND | MAX6849KAVD7 |
| 2156-MAX6431DHUS-ND | MAX6431DHUS |
| 2156-MAX6441KAKQVD3-ND | MAX6441KAKQVD3 |
| 2156-MAX6437UT-ND | MAX6437UT |
| 2156-MAX6439UTEISD3-ND | MAX6439UTEISD3 |
| 2156-MAX6849KASD3-ND | MAX6849KASD3 |
| 2156-MAX1526ETM-ND | MAX1526ETM |
| 2156-MAX8695PELR+T-ND | MAX8695PELR+T |
| 2156-MAX1612EEE±ND | MAX1612EEE+ |
| 2156-MAX1666AEEP±ND | MAX1666AEEP+ |
| 2156-MAX1773AEUP-ND | MAX1773AEUP |
| 2156-MAX1773EUP±ND | MAX1773EUP+ |
| 2156-MAX17050X-C01+T10-ND | MAX17050X-C01+T10 |
| 2156-MAX1894XEEE-ND | MAX1894XEEE |
| 175-MAX17047G+T10TR-ND,175-MAX17047G+T10CT-ND | MAX17047G+T10 |
| 505-MAX17320X20±ND | MAX17320X20+ |
| 2156-DS2437S/TR/-ND | DS2437S/T&R/ |
| 2156-MAX17077ETM±ND | MAX17077ETM+ |
| MAX6780LTB+TTR-ND,MAX6780LTB+TCT-ND,MAX6780LTB+TDKR-ND,2156-MAX6780LTB+T-ND | MAX6780LTB+T |
| 2156-MAX1613EEE±ND | MAX1613EEE+ |
| 2156-MAX8697SEWQ+T-ND | MAX8697SEWQ+T |
| 2156-MAX1781ETM+C6D-ND | MAX1781ETM+C6D |
| 2156-MAX1789EUI+T-ND | MAX1789EUI+T |
| 2156-MAX1789EUI+CBH-ND | MAX1789EUI+CBH |
| 2156-MAX6430ORUS-ND | MAX6430ORUS |
| 2156-DS1610-ND | DS1610 |
| 2156-MAX1787EUI+GH8-ND | MAX1787EUI+GH8 |
| MAX17049G±ND | MAX17049G+ |
| MAX38888ATD±ND | MAX38888ATD+ |
| MAX17301X±ND | MAX17301X+ |
| 505-MAX17300X±ND | MAX17300X+ |
| 2156-MAX6777LT±ND | MAX6777LT+ |
| 2156-MAX4919BETD±ND | MAX4919BETD+ |
| 2156-MAX6780LTB±ND | MAX6780LTB+ |
| 2156-MAX6427EIUR±ND | MAX6427EIUR+ |
| 2156-MAX6427DHUR±ND | MAX6427DHUR+ |
| 2156-MAX6778LT±ND | MAX6778LT+ |
| 2156-MAX6775LTB±ND | MAX6775LTB+ |
| 2156-MAX6437UT±ND | MAX6437UT+ |
| 175-MAX77972EWX±ND | MAX77972EWX+ |
| DS2784G±ND | DS2784G+ |
| DS2775G±ND | DS2775G+ |
| 2156-MAX1666VEEP±ND | MAX1666VEEP+ |
| 505-MAX38886ATD±ND | MAX38886ATD+ |
| MAX17303X±ND | MAX17303X+ |
| 175-MAX17320G20+TTR-ND,175-MAX17320G20+TCT-ND,175-MAX17320G20+TDKR-ND | MAX17320G20+T |
| 175-MAX17335X22+TTR-ND,175-MAX17335X22+TCT-ND,175-MAX17335X22+TDKR-ND | MAX17335X22+T |
| MAX14607EWL+TTR-ND,MAX14607EWL+TCT-ND,MAX14607EWL+TDKR-ND | MAX14607EWL+T |
| MAX17211G±ND | MAX17211G+ |
| MAX6430EGUS+TTR-ND,MAX6430EGUS+TCT-ND,MAX6430EGUS+TDKR-ND | MAX6430EGUS+T |
| MAX8682ETM±ND | MAX8682ETM+ |
| 175-MAX17332X22+TTR-ND,175-MAX17332X22+TCT-ND,175-MAX17332X22+TDKR-ND | MAX17332X22+T |
| MAX17048G±ND | MAX17048G+ |
| MAX14671EWL+T-ND | MAX14671EWL+T |
| MAX16914AUB+T-ND | MAX16914AUB+T |
| MAX16915AUB+T-ND | MAX16915AUB+T |
| DS2703U+T&R-ND | DS2703U+T&R |
| 505-MAX6778LT+TTR-ND | MAX6778LT+T |
| 505-MAX17313X+TTR-ND | MAX17313X+T |
| 505-MAX17303G+TTR-ND | MAX17303G+T |
| 505-MAX17313G+TTR-ND | MAX17313G+T |
| 505-MAX17313G±ND | MAX17313G+ |
| MAX17201X+T0E-ND | MAX17201X+T0E |
| MAX17211X+T-ND | MAX17211X+T |
| MAX17211X+T0E-ND | MAX17211X+T0E |
| MAX17211G+T-ND | MAX17211G+T |
| MAX17201G+T0E-ND | MAX17201G+T0E |
| MAX17211G+T0E-ND | MAX17211G+T0E |
| 505-MAX6427EIUR+TTR-ND | MAX6427EIUR+T |
| 505-MAX17320X10+TTR-ND | MAX17320X10+T |
| 505-MAX6780LTA+TTR-ND | MAX6780LTA+T |
| 505-MAX6779LTB+TTR-ND | MAX6779LTB+T |
| 505-DS2703U±ND | DS2703U+ |
| MAX16916GUB/V+T-ND | MAX16916GUB/V+T |
| 505-MAX17320X22+TTR-ND | MAX17320X22+T |
| 505-MAX17320G10+TTR-ND | MAX17320G10+T |
| 505-MAX17320X12+TTR-ND | MAX17320X12+T |
| MAX17205X+T-ND | MAX17205X+T |
| MAX17205X+T0E-ND | MAX17205X+T0E |
| MAX17215X+T-ND | MAX17215X+T |
| MAX17215X+T0E-ND | MAX17215X+T0E |
| 505-MAX17300G+TTR-ND | MAX17300G+T |
| 505-MAX17310G+TTR-ND | MAX17310G+T |
| 505-MAX6427ORUR+TTR-ND | MAX6427ORUR+T |
| MAX17205G+T0E-ND | MAX17205G+T0E |
| MAX17215G+T0E-ND | MAX17215G+T0E |
| 505-MAX17302X+TTR-ND | MAX17302X+T |
| 505-MAX17312X+TTR-ND | MAX17312X+T |
| 505-MAX17312G+TTR-ND | MAX17312G+T |
| 505-MAX17302G+TTR-ND | MAX17302G+T |
| MAX14654EWC+T-ND | MAX14654EWC+T |
| MAX14655EWC+T-ND | MAX14655EWC+T |
| 505-MAX17320G22+TTR-ND | MAX17320G22+T |
| 505-MAX17320G12+TTR-ND | MAX17320G12+T |
| 505-MAX17302G±ND | MAX17302G+ |
| 505-MAX17312G±ND | MAX17312G+ |
| 505-MAX17301G+TTR-ND | MAX17301G+T |
| 505-MAX17311G+TTR-ND | MAX17311G+T |
| 505-MAX17311X+TTR-ND | MAX17311X+T |
| 505-MAX17300X+TTR-ND | MAX17300X+T |
| 505-MAX17310X+TTR-ND | MAX17310X+T |
| 505-MAX17311G±ND | MAX17311G+ |
| MAX17040G+TTR-ND,MAX17040G+TCT-ND,MAX17040G+TDKR-ND | MAX17040G+T |
| DS2746G+T&R-ND | DS2746G+T&R |
| MAX8672ETD+T-ND | MAX8672ETD+T |
| DS2786BG+T&R-ND | DS2786BG+T&R |
| 505-MAX17205X±ND | MAX17205X+ |
| 175-MAX17049G+T10TR-ND,175-MAX17049G+T10CT-ND,175-MAX17049G+T10DKR-ND | MAX17049G+T10 |
| 505-MAX20095ATIA/VY+TTR-ND | MAX20095ATIA/VY+T |
| DS2780G+T&R-ND | DS2780G+T&R |
| DS2764AE+T&R-ND | DS2764AE+T&R |
| MAX6776LTA+TTR-ND,MAX6776LTA+TCT-ND,MAX6776LTA+TDKR-ND | MAX6776LTA+T |
| 505-ADES1756GCB/V+TTR-ND | ADES1756GCB/V+T |
| MAX20335BEWX+T-ND | MAX20335BEWX+T |
| DS2780E+T&R-ND | DS2780E+T&R |
| DS2777G+T&R-ND | DS2777G+T&R |
| DS2776G+T&R-ND | DS2776G+T&R |
| DS2778G+T&R-ND | DS2778G+T&R |
| DS2775G+T&R-ND | DS2775G+T&R |
| DS2764BE+T&R-ND | DS2764BE+T&R |
| 505-ADES1755GCB/V+TTR-ND | ADES1755GCB/V+T |
| 505-ADES1754GCB/V+TTR-ND | ADES1754GCB/V+T |
| MAX17841BGUE+T-ND | MAX17841BGUE+T |
| DS2762BE+T&R-ND | DS2762BE+T&R |
| DS2784G+T&R-ND | DS2784G+T&R |
| MAX20303CEWN+T-ND | MAX20303CEWN+T |
| MAX20303DEWN+T-ND | MAX20303DEWN+T |
| MAX20303HEWN+T-ND | MAX20303HEWN+T |
| MAX20303AEWN+T-ND | MAX20303AEWN+T |
| MAX20303EEWN+T-ND | MAX20303EEWN+T |
| MAX20303GEWN+T-ND | MAX20303GEWN+T |
| 505-MAX20303LEWN+TTR-ND | MAX20303LEWN+T |
| 505-MAX20303JEWN+TTR-ND | MAX20303JEWN+T |
| MAX1259CWE+T-ND | MAX1259CWE+T |
| 505-MAX17852ACB/V+TTR-ND | MAX17852ACB/V+T |
| MAX17830GUN+T-ND | MAX17830GUN+T |
| MAX17843ACB/V+T-ND | MAX17843ACB/V+T |
| MAX6431NQUS+T-ND | MAX6431NQUS+T |
| MAX6428BGUR+T-ND | MAX6428BGUR+T |
| MAX11080GUU±ND | MAX11080GUU+ |
| MAX11068GUU±ND | MAX11068GUU+ |
| MAX11068GUU+T-ND | MAX11068GUU+T |
| MAX11080GUU+T-ND | MAX11080GUU+T |
| DS2731E±ND | DS2731E+ |
| DS2731E+T&R-ND | DS2731E+T&R |
| DS2703G+T&R-ND | DS2703G+T&R |
| MAX8682ETM+T-ND | MAX8682ETM+T |
| MAX17041G+T-ND | MAX17041G+T |
| 175-MAX17043G+TTR-ND,175-MAX17043G+TCT-ND,175-MAX17043G+TDKR-ND | MAX17043G+T |
| MAX11080GUU/V±ND | MAX11080GUU/V+ |
| MAX11080GUU/V+T-ND | MAX11080GUU/V+T |
| MAX17044G+T-ND | MAX17044G+T |
| MAX11081GUU/V+T-ND | MAX11081GUU/V+T |
| MAX17040G+U-ND | MAX17040G+U |
| MAX17043G+U-ND | MAX17043G+U |
| MAX17040X+U-ND | MAX17040X+U |
| MAX17048X±ND | MAX17048X+ |
| MAX17049X±ND | MAX17049X+ |
| MAX11068GUU/V+T-ND | MAX11068GUU/V+T |
| MAX17043X±ND | MAX17043X+ |
| MAX17040X+T10-ND | MAX17040X+T10 |
| MAX17043X+T10-ND | MAX17043X+T10 |
| MAX17044X+T10-ND | MAX17044X+T10 |
| MAX17049X+T10-ND | MAX17049X+T10 |
| MAX16916GUB/V±ND | MAX16916GUB/V+ |
| MAX1924VEEE±ND | MAX1924VEEE+ |
| MAX17055EWL±ND | MAX17055EWL+ |
| MAX17840AGUN/V+T-ND | MAX17840AGUN/V+T |
| MAX20303BEWN±ND | MAX20303BEWN+ |
| MAX17260SEWL±ND | MAX17260SEWL+ |
| MAX17262REWL±ND | MAX17262REWL+ |
| MAX6433UK/GG8-ND | MAX6433UK/GG8 |
| MAX6776XKA±ND | MAX6776XKA+ |
| MAX17302X±ND | MAX17302X+ |
| MAX17311X±ND | MAX17311X+ |
| MAX17312X±ND | MAX17312X+ |
| MAX17313X±ND | MAX17313X+ |
| 505-MAX17853ACB/V+TTR-ND | MAX17853ACB/V+T |
| 505-MAX17041G+U-ND | MAX17041G+U |
| 505-MAX17201X±ND | MAX17201X+ |
| 505-MAX1660EEE±ND | MAX1660EEE+ |
| 505-MAX20360AEWZ±ND | MAX20360AEWZ+ |
| 175-MAX17320X22+TR-ND | MAX17320X22+ |
| MAX17260XEVKIT#-ND | MAX17260XEVKIT# |
| MAX17261GEVKIT#-ND | MAX17261GEVKIT# |
| MAX17262XEVKIT#-ND | MAX17262XEVKIT# |
| MAX17263GEVKIT#-ND | MAX17263GEVKIT# |
| 505-MAX17332X2EVKIT#-ND | MAX17332X2EVKIT# |
| 505-MAX17048EVKIT#-ND | MAX17048EVKIT# |
| MAX17303XEVKIT#-ND | MAX17303XEVKIT# |
| MAX17205GEVKIT#-ND | MAX17205GEVKIT# |
| MAX17055GEVKIT#-ND | MAX17055GEVKIT# |
| 505-MAX17320G1EVKIT#-ND | MAX17320G1EVKIT# |
| 505-MAX17330X2EVKIT#-ND | MAX17330X2EVKIT# |
| 505-MAX17320X1EVKIT#-ND | MAX17320X1EVKIT# |
| 505-MAX17300XEVKIT#-ND | MAX17300XEVKIT# |
| MAX17201GEVKIT#-ND | MAX17201GEVKIT# |
| MAX17205XEVKIT#-ND | MAX17205XEVKIT# |
| MAX17211XEVKIT#-ND | MAX17211XEVKIT# |
| MAX17215XEVKIT#-ND | MAX17215XEVKIT# |
| 505-MAX77787JEVKIT#-ND | MAX77787JEVKIT# |
| 505-MAX77789EVKIT#-ND | MAX77789EVKIT# |
| 505-MAX17320G2EVKIT#-ND | MAX17320G2EVKIT# |
| MAX17301XEVKIT#-ND | MAX17301XEVKIT# |
| MAX17211GEVKIT#-ND | MAX17211GEVKIT# |
| MAX17215GEVKIT#-ND | MAX17215GEVKIT# |
| MAX17055XEVKIT#-ND | MAX17055XEVKIT# |
| 505-MAX17260GEVKIT#-ND | MAX17260GEVKIT# |
| 505-MAX77751CEVKIT#-ND | MAX77751CEVKIT# |
| 505-MAX20342EVKIT#-ND | MAX20342EVKIT# |
| MAX17311XEVKIT#-ND | MAX17311XEVKIT# |
| 505-DS2788EVKIT±ND | DS2788EVKIT+ |
| 505-MAX17049EVKIT#-ND | MAX17049EVKIT# |
| MAX17313XEVKIT#-ND | MAX17313XEVKIT# |
| 175-MAX17300GEVKIT#-ND | MAX17300GEVKIT# |
| MAX17261XEVKIT#-ND | MAX17261XEVKIT# |
| MAX17201XEVKIT#-ND | MAX17201XEVKIT# |
| 175-MAX17335X2EVKIT#-ND | MAX17335X2EVKIT# |
| 505-MAX77963EVKIT#-ND | MAX77963EVKIT# |
| 505-MAX17049XEVKIT#-ND | MAX17049XEVKIT# |
| 505-MAX17058EVKIT#-ND | MAX17058EVKIT# |
| 505-MAX17048XEVKIT#-ND | MAX17048XEVKIT# |
| MAX17302XEVKIT#-ND | MAX17302XEVKIT# |
| MAX17312XEVKIT#-ND | MAX17312XEVKIT# |
| 505-MAX17310XEVKIT#-ND | MAX17310XEVKIT# |
| 505-MAX17047EVKIT#-ND | MAX17047EVKIT# |
| 505-DS2782EVKIT±ND | DS2782EVKIT+ |
| 505-DS2786EVKIT±ND | DS2786EVKIT+ |
| MAX17050EVKIT#-ND | MAX17050EVKIT# |
