Hey! I do not really know a whole lot about hardware or even connectors for that matter. I was looking at the CEVAL-055 (https://www.digikey.com/en/products/detail/crystek-corporation/CEVAL-055/1826573) board for a VCO and had a question about the SMA connector on there. I tried googling around but could not really find a definitive answer.
All 3 connectors on the eval board seem to be female SMA. I expected the RF output to be SMA and know that it will connect to a male SMA for connection to other components in the downstream. However, I am not sure how to connect Vcc and Vt on the CEVAL-055 using a SMA connector. What I mean is, Vcc is the power supply voltage, let’s say coming from a battery. How do I connect the 0V and 12V wires to the female SMA connector? I am sure there must exist a connector for that. Can someone point me to it?
Similarly, for the Vt, the signal is going to be a low frequency signal. Something on the order of a few kHz. I am guessing the same connector can be used for that?
I appreciate any help that i can get here. Cheers!
