Searching for Replacement parts
Hello everyone,
I’m looking for a replacement for the red LEDs used in a Fisher & Paykel 10 kg top-load washing machine. Each LED is about 6 mm long, mounts flush to the PCB with side tabs, and measures around 1.7 V forward voltage in diode-test mode. The marking on the body is “3A56,” but I can’t find any matches for that in part searches. I’ve attached photos to show the shape and mounting style.
If anyone has sourced an equivalent or knows a suitable replacement, I’d really appreciate your input. Thanks in advance for the help!
Not 6mm but 4mm
Welcome to the technical forum. Is it possible to get a picture of the Led? That might be useful to try to match it .
I found these that look similar Red Surface Mount, Bottom Entry LED Indication - Discrete | Electronic Components Distributor DigiKey
Please verify with mfrs data sheets
