STPMIC25 as New-Product-Highlight for STM32MP25 – 2nd Gen application µP as companion PMIC
STPMIC25 is a New-Product-Highlight for STMicroelectronics’ STM32MP25 – 2nd Generation application processors and there is a companion PMIC with dedicated pin configuration options
STPMIC25 Power Management IC NPH from STMicroelectronics @ DigiKey
Consider possible configuration of STPMIC25 Input/Output pins from STM
STPMIC25 digital pin config
Pin
number
Pin name Type If not
used
1 PONKEYn I Floating
30 WAKEUPn I Floating
31 RSTn I/O Floating
32 INTn O Floating
33 SCL I VIO
34 SDA I/O VIO
54 PWRCTRL3 I Floating
55 PWRCTRL2 I Floating
56 PWRCTRL1 I Floating
STPMIC25 power analog IO pin config
Pin
number
Pin name Type If not used
2 LDO8OUT O Floating
3 LDO78IN I VIN
4 LDO7OUT O Floating
5 LDO6OUT O Floating
6 LDO56IN I VIN
7 LDO5OUT O Floating
12 VBUS I Floating
13 LDO4OUT O Floating
14 LDO1OUT O Floating
15 LDO12IN I VIN
16 LDO2OUT O Floating
17 VOUT4 I Floating
19 VLX4 O Floating
20 BUCK4IN I VIN
21 VOUT3 I Floating
23 VLX3 O Floating
24 BUCK3IN I VIN
25 BUCK2IN I VIN
26 VLX O Floating
28 VOUT2 I Floating
35 VOUT5 I Floating
37 VLX5 O Floating
38 BUCK5IN I VIN
39 BUCK1IN I VIN
40 VLX1 O Floating
42 VOUT1 I Floating
43 LDO3IN I VIN
44 LDO3OUT O Floating
45 VREFDDR O Floating
46 VOUT6 I Floating
48 VLX6 O Floating
49 BUCK6IN I VIN
50 BUCK7IN I VIN
51 VLX7 O Floating
53 VOUT7 I Floating
Check out: en.DM01075498 AN6115 from STM on STPMIC25 – how to connect unused PINs
en.DM01075498 AN6115 from STM on STPMIC25 - how to connect unused PINs.pdf (225.7 KB)
