Temperature and humidity sensor
Hi I’m looking for a sensor that can measure air flow temperature and humidity. We will connect the HVAC system via flexible ducts for testing and use the sensor to record the temperature and humidity of air flow. We also want the sensors that can connect with data logger (CR3000). Is there any recommendation for such requirements?
I am not seeing any sensor that has the air flow and also the temperature and humidity. The temperature and humidity sensors would be located on this link: https://www.digikey.com/short/9pvcptbj
There are multiple output types . I tried to read up on the data logger you are using, but there seems to be multiple options on that also. The data logger is not something we sell.
The air flow sensors we sell are on this link: https://www.digikey.com/short/cm2dpdh7
Look through the lists and let us know if you have any other questions.
If I’m using a logger as high accuracy and expensive as a Campbell Scientific CR3000, I prefer to use the sensors sold by Campbell Scientific. https://www.campbellsci.com/relative-humidity
