New to electronic engineering!. Trying to calculate what Watt resistor to put into a pyro channel. I’m making a PCB for model rocketry (just for some context of what I’m doing).
If I have a terminal block (OSTTE040104) and I send 12 Volts through it will it be 12 volts that come out the other side that will then go into a resistor and?
12V > Terminal OUT > Terminal IN > (1 Ohm) Resistor> Mosfet > Pull Down (470 Ohms)Resistor/Ground
