Timer relay DPDT 5-12VDC Trigger
I need the part number for a timer relay adjustable from 1-5 minutes that will accept a 5-12vdc trigger input. Suggestions?
Hello @georgegarner !
Welcome to DigiKey’s TechForum.
One moment please while I look into your inquiry.
Thank you,
Victoria
Check out the Selec 600XU-A-1-CU. It has an adjustable timer range that covers 1–5 minutes and includes a dedicated trigger input (Y1).
That said, the control input is rated for 12–240 VDC/AC, so it won’t reliably trigger at 5V.
Here is a list of some other options that may work for you.
Thank you,
Victoria
