I have broken off a USB connector from my EarMen Eagle DAC. It’s unfortunate because I had been using an adapter cable to prevent this kind of thing from happening, but recently stopped using the adapter because it was fitting a bit loose and inserting the Eagle directly helped prevent disconnects. I should have just tightened the USB port’s dual pins in the first place but here I am.
The connector is a golden USB 1/2 4-pin, horizontal pins, right angle mount, through hole. Even with these parameters there are still 150+ results on digikey so I hoped someone could identify the best fit part. Pictures: Imgur: The magic of the Internet
