Xilinx DLC10 info needed
I am looking for info on what software is needed to run this unit and where I can get it.
4 days running thru Xilinx web site, it is merry go round that does not stop.
I need to read from and write to some chips.
Can anyone tell me what software I need and where I can get it?
Hi Bob, I do not see that we carry any CLD10 components from Xilinx. Do you have the DigiKey part number so I can look at the data sheet on it? Glenda
Hi Glenda, DigiKey P/N
122-1572-ND
I Guess CDL10 is a model #
Bob
Hi Bob, here is the data sheet, in it says you need to use the Impact software which you can down load off of the xilinx website. https://www.xilinx.com/ Glenda
Hi Glenda, I searched for 4 days on their web site and could not fine it.
Hello Bob,
The Xilinx iMPACT software is bundled with their older development suite ISE. You can find the archived downloads here: https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/vivado-design-tools/archive-ise.html
If you only need the programming utilities, you can simply download the Lab Tools as shown below instead of the full development environment.
If I am correctly reading the information in this Xilinx Forum link, the Lab Tools utilities may only work with Windows 7, Windows XP, or Windows Server, so be aware of that.
By the way, it is the DLC10 rather than the CLD10, which might have caused the original confusion.
HI Bob, you can also check this link out.
