Lithium batteries (or hybrid LIC capacitors) are different from other chemistries. These are highly sensitive to voltage and should always be above their required minimum discharge voltage but also below their maximum charge voltage required by the battery. Charging or discharging a lithium beyond the min and max voltages results in cell damage, injury, or fire.
It is common to see a single cell LiPo (non-HV / non high voltage) with a minimum discharge voltage of 3.2 volts per cell with a maximum charge voltage of 4.2 volts per cell, which produces about 3.7 volts under load. However, the recommended voltages will vary depending on your exact battery specifications, as this is more of an outline to showcase voltage importance.
Similar to lithium’s min and max voltage requirement, they also need to be stored at a certain charged capacity. Li-ion / LiPo should be stored approximately “half full” (40% – 50% of full charge) which does not mean half the battery voltage, but rather half of the battery’s charge capacity.
Li-ion / LiPo batteries function via a chemical reaction that occurs inside their sealed enclosure. Providing power is a chemical reaction, while the aging/degrading process is another chemical reaction. Chemical reaction doubles its speed for every ten degrees increase of ambient temperature.
Tech Tip: It is best to store & charge batteries in a fireproof container. Some prefer to store their batteries in a refrigerator, as this not only slows down the chemical reaction process extending overall battery life, but also serves somewhat as a fireproof container rather than leaving them stored next to cardboard or curtains. Just make sure to properly discard all food in the event the batteries would have an issue - use of a plastic zip bag may help indicate any signs of cell malfunction.
See Also:
Charging / storing small generic lipo batteries
Important Precautions for Proper Handling, Storage, & Use of Hybrid Lithium Supercapacitors
Sealed Lead Acid vs Lithium Iron Phosphate Batteries
Charging Lead Acid Battery Basics
Cell balancing and battery replacement
How To Use, Maintain and Dispose of Batteries
Overview of Batteries in Series or Parallel
How To RENEW CAR & TRUCK Batteries at Home
Preventive Maintenance of Lead Acid Batteries
Battery Packs
Batteries Rechargeable (Secondary)
Battery Shelf Life
Battery Storage and Handling FAQs with Aaron Cunningham from Zeus Battery
Summary
shelf life
lithium
ion
polymer
728-1052-2-ND,728-1052-1-ND,728-1052-6-ND
728-1134-ND
728-1057-ND
728-MS621RII27ETR-ND,728-MS621RII27ECT-ND
728-MS421RIV03ETR-ND,728-MS421RIV03ECT-ND
SY103-ND
728-1058-ND
P047-ND
728-1084-ND
728-1077-ND
P664-ND
P080-ND
1568-1496-ND
2059-PCIFR18650-1500-ND
1568-1491-ND
P085-ND
1528-1858-ND
1568-1490-ND
1572-1617-ND
1528-1841-ND
1908-LP503562JU+PCM+2WIRES50MM-ND
P088-ND
P087-ND
1528-1838-ND
1528-1836-ND
1939-2034-ND
1568-PRT-18286-ND
1568-1495-ND
495-B73180A0101M062TR-ND,495-B73180A0101M062CT-ND,495-B73180A0101M062DKR-ND
1908-LP443441JU+PCM+2WIRES50MM-ND
1572-1628-ND
1528-1857-ND
1572-1621-ND
1568-1686-ND
1471-MIKROE-4474-ND
1908-LI18650JP1S1P+PCM+2WIRES70MM-ND
1908-LP103450JH+PCM+PTC+2WIRES70MM-ND
1572-1625-ND
1908-LP675365JU+PCM+2WIRES70MM-ND
1908-LP906090JH+PCM+2WIRES70MM-ND
1908-LP735977JH+PCM+2WIRES70MM-ND
1908-LI18650JP2S2P+PCM+2WIRES70MM-ND
1908-LI18650JP1S2P+PCM+2WIRES70MM-ND
1910-PIS-1129-ND
3164-PSL-SC-12200-NB1-ND
P006-ND
728-1053-ND
728-1054-ND
728-1055-ND
SY152-ND
728-1078-ND
P046-ND
P045-ND
728-1081-ND
P665-ND
728-1082-ND
P079-ND
P081-ND
P082-ND
1832-1045-ND
SLB03090LR801BT-ND
P086-ND
P002-ND
1528-1837-ND
1528-1839-ND
SLB08115L1401PH-ND
1908-LP402025JU+PCM+2WIRES50MM-ND
1471-MIKROE-4471-ND
1832-1051-ND
1908-LP333437JU+PCM+2WIRES50MM-ND
1471-1865-ND
1908-LP561836JU+PCM+2WIRES50MM-ND
1908-LP503040JH+PCM+2WIRES50MM-ND
1908-LP851719JU+PCM+2WIRES50MM-ND
1939-2033-ND
1908-LP402535JU+PCM+2WIRES50MM-ND
2059-PCIFR26650-3400-ND
1908-LP305166JH+PCM+2WIRES70MM-ND
1908-LP422339JU+PCM+2WIRES50MM-ND
1471-MIKROE-4473-ND
1908-LP603443JU+PCM+2WIRES70MM-ND
1908-LI18650JLSHB3.35AHPROTECTED-ND
1908-LP523450JU+PCM+2WIRES70MM-ND
1908-LP503759JU+PCM+2WIRES70MM-ND
1908-LP103048JU+PCM+2WIRES70MM-ND
1908-LP102530JU+PCM+2WIRES50MM-ND
1908-LP523450JU+PCM+JSTPHR-370MM-ND
1572-1629-ND
1572-1632-ND
11-CG-425A/M3-ND
1908-LP504783JU+PCM+2WIRES70MM-ND
11-CG-320B/M3-ND
1939-BL3000F9031781S1PCNC-ND
11-CG-420A/M3-ND
1572-1627-ND
1908-LI18650JP2S1P+PCM+2WIRES70MM-ND
1939-2038-ND
3164-PSL-SC-1270F2-ND
3164-PSL-SC-1290F2-ND
728-1085-ND
SLB03070LR351BS-ND
1908-LI18650JC1S1P+PCM+FUSE+2WIRES70MM-ND
1572-1630-ND
1908-LP463042JU+PCM+2WIRES50MM-ND
1908-LP603048JK+PCM+2WIRES70MM-ND
SLB12400L1516ZA-ND
1572-1618-ND
1572-1620-ND
1939-BL1200P4054481S1PCAC-ND
1939-2037-ND
1908-LP605060JU+PCM+2WIRES70MM-ND
1908-LP705176JS+PCM+2WIRES70MM-ND
SLB08115L1401PM-ND
SLB03070LR352TR-ND,SLB03070LR352CT-ND
SLB08115L1401CV-ND
1908-LP633750JH+PCM+2WIRES70MM-ND
1939-2036-ND
SLB12400L1511CV-ND
1939-BL0900CAA651S1PCWNST-ND
1939-BL0900CAA651S1PCBG-ND
1939-BL0900CAA651S1PCCTJS2-ND
1572-1626-ND
SLB12400L1511CA-ND
SLB04255L0401ED-ND
1908-LP883550JU+PCM+2WIRES70MM-ND
338-RJD2048ST8-ND
338-RJD2440SP8-ND
1939-BL1950P4071611S1PCPT-ND
1908-LI21700JSV-50+PCM+FUSE+3WIRES70MM-ND
1908-LP685077JU+PCM+2WIRES70MM-ND
3164-PSL-FP-IFP2770180EC-ND
P044-ND
P663-ND
P294-ND
MS920SE-ND
3145-LIFEO4-14430-ND
2375-ICR14430-650-F-ND
3145-LIFEO4-14505-ND
3544-USE-18650-2200MAH-ND
3145-UL14430SL-2P-ND
2375-ICR18650-2200-F-ND
3544-USE-18650-2600MAH-ND
3544-USE-18650-3500MAH-ND
3544-USE-18650-2200PCB-ND
2375-ICR18650-2600-F-ND
490-CT04120-ND
3544-USE-18650-2600PCB-ND
3544-USE-702528-500PCBJST-ND
3145-LION-1865-26-ND
3145-UL1865-26-1P-ND
3544-USE-18650-2000PCBUSB-ND
3145-UL14500SL-2P-ND
3544-USE-18650-3500PCB-ND
3544-USE-18650-2200PCBJST-ND
3544-USE-18650-2600PCBJST-ND
3145-UL18500SL-2P-ND
3544-USE-803048-1100mAh-ND
3145-L37A26-1-0-2WX-ND
3145-L37A26-1-0-3WA3-ND
3145-LION-1865-34-ND
3145-UL1865-34-1P-ND
3145-UL1865-26-2P-ND
3544-USE-903439-1400mAh-ND
3544-USE-104060-3K-PCBJST-ND
3145-LIFEO4-18650-ND
1908-LI21700JS1S1P+PCM+2WIRES70MM-ND
2375-ICR18650-4400W/JST-PHR-2P-ND
3145-UL1865-34-2P-ND
3145-UL1865K-26-ND
3027-LP735977JH+PCM+2WIRES70MM-ND
2612-PCLFP8-12.8SPF2-ND
2612-PCLFP12-12.8SPF2-ND
5343-LITHIUM12.8V10AH-ND
5343-LITHIUM12.8V12AH-ND
3491-LFP12V50AB-ND
2612-PCLFP20-12.8SPM5-ND
5343-LITHIUM12.8V50AH-ND
3491-LFP12V200AB-ND
5482-PHD21700-5-ND
5194-LP443441JU+PCM+2WIRES50MM-ND
5194-LI14500J1S1P+PCM+WIRE45MM-ND
3027-LI18650JLSHB3.35AHPROTECTED-ND
5343-LITHIUM12.8V8AH-ND
5539-BB1250TB-ND
5539-BB1275TB-ND
5539-BB5024TB-ND
5539-BB10012-ND
5539-BBGC2TB-ND
5539-BB5024H-1KITTB-ND
5539-BB10012H-1KITTB-ND
5539-BBGC2H-1KITTB-ND
5539-BBGC3TB-ND
5539-BBGC3H-1KITTB-ND
1528-1840-ND
1528-1835-ND
1528-5035-ND
728-1079-ND
3164-PSL-FP-IFR18650EC-ND
1832-1032-ND
1528-4237-ND
1528-4236-ND
1471-MIKROE-698-ND
1908-LP502243JU+PCM+2WIRES50MM-ND
1832-1044-ND
1908-LP502030JH+PCM+2WIRES50MM-ND
1568-1876-ND
1471-1023-ND
1572-1624-ND
1572-1633-ND
1572-1634-ND
1471-MIKROE-4475-ND
1910-PIS-1189-ND
1572-1635-ND
1939-2039-ND
1706-1000-ND
1572-1622-ND
1572-1631-ND
1572-1623-ND
1939-BL2600C1865001S2PRMS-ND
1568-1494-ND
1910-PIS-1131-ND
SLB03070LR356ZA-ND
1939-BL0800F5424651S1PSXH-ND
1939-2035-ND
3164-PSL-SC-12100F2-ND
1706-1002-ND
1568-PRT-25270-ND
1939-BL3350C1865001S1PXJT-ND
2375-ICR10440-350-B-ND
2375-ICR14500-800-F-ND
2375-ICR18650-3350-F-ND
1908-LP802036JU+PCM+2WIRES50MM-ND
3544-USE-18650-3500PCBJST-ND
2700-903-0220-000-ND
2375-ICR26650-5000-F-ND
1908-LI18650JLPROTECTED-ND
3145-300-10186-ND
2700-903-0143-001-ND
2700-903-0143-000-ND
2700-903-0210-000-ND
2059-PCLFP10-12.8F2-ND
5343-LITHIUM12.8V20AH-ND
3164-PSL-SH-12110F2-ND
2984-AG-ATX12-RS-ND
2984-AG-ATX20-HD-ND
5194-LP851719JU+PCM+2WIRES50MM-ND
5194-LP503040JH+PCM+2WIRES50MM-ND
5194-LP603443JU+PCM+2WIRES70MM-ND
5194-LP102530JU+PCM+2WIRES50MM-ND
5194-LP605060JU+PCM+2WIRES70MM-ND
5194-LP906090JH+PCM+2WIRES70MM-ND
2984-AG-401-ND
2984-AG-ATZ7-RS-ND
2984-AG-ATZ10-RS-ND
2984-AG-1201-ND
2984-AG-801-ND
2984-AG-AT12BS-HD-RS-ND
2984-AG-1601-ND
2984-AG-ATX20-RS-ND
5539-BB1250-1KITTB-ND
5539-BB1275H-1KITTB-ND
4372-56654799098-ND
728-1080-ND
1832-1031-ND
1568-1493-ND
1568-1488-ND
1528-2731-ND
1832-1050-ND
1528-1834-ND
3164-PSL-SC-12120F2-ND
1832-1052-ND
495-Z62000Z2910Z01Z05-ND
1832-1053-ND
1908-LP501218JH+PCM+2WIRE50MM-ND
1908-LI14500J1S1P+PCM+WIRE45MM-ND
1572-1619-ND
1939-BL3000F9031781S1PCRV-ND
1939-BL3500C1865001S1PCMK-ND
3164-PSL-FP-IFR26650PC-ND
1939-2040-ND
Z7892-ND
SLB08115L1406ZA-ND
1471-MIKROE-2625-ND
1908-LP384260JU+PCM+MOLEX51021-020035MM-ND
1908-LP523450JU+PCM+MOLEX51021-030070MM-ND
1939-BL2200F9031781S1PCKT-ND
1939-BL4800C2170001S1PCAS-ND
11-ML-421S-ND
TS414H-IV01E-ND
MS412FE-ND
MS414GE-ND
728-1042-2-ND
MS518SE-ND
P007-ND
MS614SE-ND
MS414GE-FL26E-ND
P003TR-ND
P004TR-ND
TS621FE-FL11E-ND
P296-ND
P295-ND
ML-2020/BN-ND
VL-1220/HF1N-ND
493-SLB03070LR351BT-ND
SLB03070LR353ZA-ND
SLB03070LR351ZA-ND
P048-ND
SLB03070LR354ZA-ND
VL-2330/G1BN-ND
3164-PSL-FP-IFR18650PC-ND
VL-2330/G1CN-ND
3164-PSL-FP-IFR26650EC-ND
3254-GRP402425-3.8V-225MAH-ND
3254-GRP392231-3.7V-190MAH-ND
3254-GRP653929-3.85V-665MAH-ND
3254-GRP084949-3.7V-135MAH-ND
3254-GRP401430-3.7V-105MAH-ND
3254-GRP483535-3.8V-545MAH-ND
3254-GRP604543-3.7V-1050MAH-ND
3254-GRP652348-3.8V-850MAH-ND
2375-ICR18650-2600-B-ND
497-14838-2-ND
3254-GRP473027-1C-3.8V-330MAHWITHPCM-ND
1939-BL1800P0639602S1PPLB-ND
497-17638-2-ND
11-K-KJ17MCA4BA-ND
11-K-KJ17MCC82A-ND
1706-DR202E-ND
1706-DR202XP-ND
2084-POC-IPSM90B2-ND
2375-ICR18650-2200W/JST-PHR-2P-ND
3145-LIFEO4-18500-ND
P084-ND
P083-ND
P043-ND
P009-ND
P298-ND
P297-ND
P285-ND
P219-ND
P221-ND
P005-ND
SY102-ND
SY104-ND
SY105-ND
MS412FE-IL21E-ND
MS614SE-IL38E-ND
MS621FE-IL36E-ND
MS920SE-IL37E-ND
TS518F-FL35E-ND
TS518F-FL36E-ND
TS621F-FL11E-ND
728-1040-2-ND,728-1040-1-ND
728-1041-2-ND
728-1043-ND
728-1044-ND
728-1045-ND
728-1046-ND
728-1047-ND
728-1048-ND
TS518FE-FL35E-ND
TS621FE-IL36E-ND
728-1056-ND
3Z49-BAT1-ND
SY615-ND
SY616-ND
ML-1220/BN-ND
ML-1220/H1AN-ND
ML-421S/DN-ND
ML-614S/DN-ND
ML-621S/FDDN-ND
NBL-414/DN-ND
497-15109-ND
1568-1487-ND
1568-1877-ND
PRT-10319-ND
1568-1489-ND
1568-1492-ND
1706-1001-ND
28987PAR-ND
752-00010-ND
EFL1K0AF39-ND
1908-LI18650JS1S1P+PCM+2WIRES70MM-ND
1908-LP341018JSY+PCM+2WIRES50MM-ND
1908-LP501233JSY+PCM+2WIRES50MM-ND
752-00017-ND
2059-PCLFP7.5-12.8F2-ND
2059-PCLFP20-12.8M6-ND
2612-PCLFP30-12.8M6-ND
2612-PCLFP55-12.8M6-ND
2059-PCIFR26650-3300-ND
11-BK-3MCCA4BA-ND
2375-ICR18650-2600BP-1B-ND
3164-PSL-SH1270F2-ND
3164-PSL-SH-12100F2-ND
3164-PSL-SH1260F2-ND
3491-LFP12V100AB-ND
3254-GRP3922031-1C-3.7V-190MAH-ND
3254-GRP604543-1C-3.7V-1050MAHWITHPCM-ND
3254-GRP554543-1C-3.7V-960MAHWITHPCM-ND
3254-GRP443535-1C-3.7V-450MAHWITHPCM-ND
3254-GRP403530-1C-3.8V-360MAHWITHPCM-ND
3254-GRP653027-1C-3.8V-430MAHWITHPCM-ND
3254-GRP292434-1C-3.7V-210MAHWITHPCM-ND
1908-LP501233JCELL-ND
2414-TPBAT12-10-L-ND
2414-TPBAT12-50-L-ND
3491-LFP48V150A-ND
ML414H IV01E
MS621FE
MS621FE-FL11E
MS621R II27E
MS421R IV03E
ML621-TZ1
MS920SE-FL27E
ML-2020/H1CN
TS621E-FL11E
MS920T-FL27E
ML-2020/F1AN
VL-1220/VCN
PRT-13852
PCIFR18650-1500
PRT-13853
VL-2330/HFN
2750
PRT-13189
RJD2032C1
1578
LP503562JU+PCM+2 WIRES 50MM
VL-3032/F2N
VL-3032/GUFN
258
1781
BL0750F5030481S1PCMC
PRT-18286
PRT-13854
B73180A0101M062
LP443441JU+PCM+2 WIRES 50MM
RJD2032C1ST1
2011
RJD2450
PRT-13855
MIKROE-4474
LI18650JP1S1P+PCM+2 WIRES 70MM
LP103450JH+PCM+PTC+2 WIRES 70MM
RJD3048HPPV30M
LP675365JU+PCM+ 2 WIRES 70MM
LP906090JH+PCM+2 WIRES 70MM
LP735977JH+PCM+2 WIRES 70MM
LI18650JP2S2P+PCM+2 WIRES 70MM
LI18650JP1S2P+PCM+2 WIRES 70MM
PIS-1129
PSL-SC-12200-NB1
ML-614S/ZTN
MS412FE-FL26E
MS518SE-FL35E
MS614SE-FL28E
ML614-TZ21
MS621T
ML-2020/G1AN
ML-2020/V1AN
TS920E
VL-1220/FCN
TS920E-FL27E
VL-1220/HFN
VL-2020/HFN
VL-2020/VCN
ASR00011
SLB03090LR801BT
VL-2330/VCN
VL-2330/F3N
1570
1317
SLB08115L1401PH
LP402025JU+PCM+2 WIRES 50MM
MIKROE-4471
ASR00035
LP333437JU+PCM+2 WIRES 50MM
MIKROE-2759
LP561836JU+PCM+2 WIRES 50MM
LP503040JH+PCM+2 WIRES 50MM
LP851719JU+PCM+2 WIRES 50MM
BL0105F2635161S1PCAT
LP402535JU+PCM+2 WIRES 50MM
PCIFR26650-3400
LP305166JH+PCM+2 WIRES 70MM
LP422339JU+PCM+2 WIRES 50MM
MIKROE-4473
LP603443JU+PCM+2 WIRES 70MM
LI18650JLS HB 3.35AH PROTECTED
LP523450JU+PCM+2 WIRES 70MM
LP503759JU+PCM+2 WIRES 70MM
LP103048JU+PCM+2 WIRES 70MM
LP102530JU+PCM+2 WIRES 50MM
LP523450JU+PCM+JST PHR-3 70MM
RJD2048ST1
RJD2450ST1
CG-425A/M3
LP504783JU+PCM+2 WIRES 70MM
CG-320B/M3
CG-420A/M3
RJD3555HPPV30M
LI18650JP2S1P+PCM+2 WIRES 70MM
BL2600C1865003S1PGMG
PSL-SC-1270 F2
PSL-SC-1290 F2
TS621E
SLB03070LR351BS
LI18650JC1S1P+PCM+FUSE+2 WIRES 70MM
RJD2430C1ST1
LP463042JU+PCM+2 WIRES 50MM
LP603048JK+PCM+2 WIRES 70MM
SLB12400L1516ZA
RJD2048
RJD2440
BL2200F6034501S2PZAL
LP605060JU+PCM+2 WIRES 70MM
LP705176JS+PCM+2 WIRES 70MM
SLB08115L1401PM
SLB03070LR352ZA
SLB08115L1401CV
LP633750JH+PCM+2 WIRES 70MM
BL2200F6034501S2PPMK
SLB12400L1511CV
BL0900CAA651S1PCBG
RJD3555
SLB12400L1511CA
SLB04255L0401ED
LP883550JU+PCM+2 WIRES 70MM
RJD2048ST8
RJD2440SP8
LI21700JSV-50+PCM+FUSE+3 WIRES 70MM
LP685077JU+PCM+2 WIRES 70MM
PSL-FP-IFP2770180EC
ML-621S/DN
ML-1220/F1BN
ML-1220/V1AN
MS920SE
LIFEO4-14430
ICR14430-650-F
LIFEO4-14505
USE-18650-2200MAH
UL14430SL-2P
ICR18650-2200-F
USE-18650-2600MAH
USE-18650-3500MAH
USE-18650-2200PCB
ICR18650-2600-F
CT04120
USE-18650-2600PCB
LION-1865-26
UL1865-26-1P
UL14500SL-2P
USE-18650-3500PCB
UL18500SL-2P
USE-803048-1100 mAh
L37A26-1-0-2WX
L37A26-1-0-3WA3
LION-1865-34
UL1865-34-1P
UL1865-26-2P
USE-903439-1400 mAh
LIFEO4-18650
LI21700JS1S1P+PCM+2 WIRES 70MM
ICR18650-4400 W/JST-PHR-2P
UL1865-34-2P
UL1865K-26
PCLFP8-12.8SP F2
PCLFP12-12.8SP F2
LITHIUM 12.8V10AH
LITHIUM 12.8V12AH
LFP12V50AB
PCLFP20-12.8SP M5
LITHIUM 12.8V50AH
LFP12V200AB
PHD 21700-5
LI14500J1S1P+PCM+WIRE 45MM
LITHIUM 12.8V8AH
BB1250
BB1275
BB5024
BB10012
BBGC2
BB5024H-1KIT
BB10012H-1KIT
BBGC2H-1KIT
BBGC3
BBGC3H-1KIT
328
353
5035
MS920T
PSL-FP-IFR18650EC
ASR00007
4237
4236
MIKROE-698
LP502243JU+PCM+2 WIRES 50MM
ASR00008
LP502030JH+PCM+2 WIRES 50MM
PRT-11855
MIKROE-1120
RJD3048
RJD3032ST1
RJD3048ST1
MIKROE-4475
PIS-1189
RJD3555ST1
BL2600C18654S1PG2646
DR202I
RJD3032
RJD2440ST1
RJD3032HPPV30M
PRT-13856
PIS-1131
SLB03070LR356ZA
BL1880F6835661S5PX9M
PSL-SC-12100 F2
DR203
PRT-25270
ICR10440-350-B
ICR14500-800-F
ICR18650-3350-F
LP802036JU+PCM+2 WIRES 50MM
903-0220-000
ICR26650-5000-F
LI18650JL PROTECTED
300-10186
903-0143-001
903-0143-000
903-0210-000
PCLFP10-12.8F2
LITHIUM 12.8V20AH
PSL-SH-12110 F2
AG-ATX12-RS
AG-ATX20-HD
AG-401
AG-ATZ7-RS
AG-ATZ10-RS
AG-1201
AG-801
AG-AT12BS-HD-RS
AG-1601
AG-ATX20-RS
BB1250-1KIT
BB1275H-1KIT
56654 799 098
MS621T-FL11E
ASR00003
PRT-13851
PRT-12895
3898
ASR00050
354
PSL-SC-12120 F2
ASR00036
B73180A0101M199
ASR00012
LP501218JH+PCM+2 WIRE 50MM
RJD2430C1
PSL-FP-IFR26650PC
BL2600C18654S1PGQG
C200H-BAT09
SLB08115L1406ZA
MIKROE-2625
LP384260JU+PCM+MOLEX 51021-0200 35MM
LP523450JU+PCM+MOLEX 51021-0300 70MM
ML-421S
TS414H-IV01E
MS412FE
MS414GE
HB414-IV02E
MS518SE
ML-621S/ZTN
MS614SE
MS414GE-FL26E
ML-414RM/AN
ML-414RM/CN
TS621FE-FL11E
ML-920S/DN
ML-1220/F1AN
ML-2020/BN
VL-1220/HF1N
SLB03070LR351BT
SLB03070LR353ZA
SLB03070LR351ZA
VL-621/DN
SLB03070LR354ZA
VL-2330/G1BN
PSL-FP-IFR18650PC
VL-2330/G1CN
PSL-FP-IFR26650EC
ICR18650-2600-B
EFL700A39-RL
GRP473027-1C-3.8V-330MAH WITH PCM
EFL1K0AF39RL
K-KJ17MCA4BA
K-KJ17MCC82A
DR202E
DR202XP
POC-IPSM90B2
ICR18650-2200 W/JST-PHR-2P
LIFEO4-18500
VL-2320/VCN
VL-2320/HFN
ML616S/F9DE
NBL-621/DN
ML612S/F9DE
ML-614S/FN
CGA-7/102FE
VL1216-1F5U
VL-2320/F2N
ML414S/ZT
ML614-TZ4
ML1220-TJ1
ML1220-TT2
MS412FE-IL21E
MS614SE-IL38E
MS621FE-IL36E
MS920SE-IL37E
TS518F-FL35E
TS518F-FL36E
TS621F-FL11E
HB414-II06E
HB414-IV01E
MS412F-FL26E
MS518S-FL35E
MS614S-FL28E
MS614S-FL29E
MS621F-FL11E
MS920S-FL27E
TS518FE-FL35E
TS621FE-IL36E
MS614SE-FL29E
3Z49-BAT1
ML2430-CJ1
ML2430-HS1
ML-1220/BN
ML-1220/H1AN
ML-421S/DN
ML-614S/DN
ML-621S/FDDN
NBL-414/DN
EFL700A39
PRT-08483
PRT-11856
PRT-10319
PRT-13112
PRT-13813
DR202X
28987
752-00010
EFL1K0AF39
LI18650JS1S1P+PCM+2 WIRES 70MM
LP341018JSY+PCM+2 WIRES 50MM
LP501233JSY+PCM+2 WIRES 50MM
752-00017
PCLFP7.5-12.8F2
PCLFP20-12.8M6
PCLFP30-12.8M6
PCLFP55-12.8M6
PCIFR26650-3300
BK-3MCCA4BA
ICR18650-2600BP-1B
PSL-SH1270 F2
PSL-SH-12100 F2
PSL-SH1260 F2
LFP12V100AB
GRP604543-1C-3.7V-1050MAH WITH PCM
GRP554543-1C-3.7V-960MAH WITH PCM
GRP443535-1C-3.7V-450MAH WITH PCM
GRP403530-1C-3.8V-360MAH WITH PCM
GRP653027-1C-3.8V-430MAH WITH PCM
GRP292434-1C-3.7V-210MAH WITH PCM
LP501233J CELL
TPBAT12-10-L
TPBAT12-50-L
LFP48V150A
