In this prerequisite article, a multiblade wire stripping tool was used to remove the outer jacket and the braided shield of an industrial Ethernet cable. This engineering brief shows how the sheathing stripper shown in Figure 1 may be used to prepare the cable. Note that this article is part of a larger cluster of articles including:
Industrial Ethernet Cable: Fixed Installation vs. Continuous Flex
How to Install a Shielded RJ45 Connector on Industrial CAT 6 Cable
Stripping PUR Cable Without Nicking the Conductor Insulation
Difficulty:
Student — difficulty levels explained
Last update: 02 Nov 2026
Figure 1: Image of the Weidmüller AM25 sheathing stripper along with a LAPP Ethernet cable and associated RJ45 connector.
Types of Scoring Performed by the Sheathing Stripper
Figure 2 shows the two types of scoring performed by the Weidmüller sheathing stripper. There are three scores shown in the picture. Two are circumferential scores with a third score running along the length of the cable. For this image, I have partially removed the first part of the cable jacket.
The cable is scored, not cut.
Figure 2: Ethernet cable prepared by the featured sheathing stripper.
Tech Tip: The sheathing stripper scores the outer jacket. Don’t use the word “cut.” As described in this article, we score the cable to prevent inadvertently nicking the underlying insulation or, in this case, damaging the cable’s shield.
Sheathing Stripper Adjustments
There are two controls for the featured sheathing stripper. Both are shown in Figure 3.
The central silver barrel controls the depth of the cutter.
The lever controls the direction of the scoring. As shown, the tool is ready to spin around the wire making a circumferential score. When placed in the far-right position, the tool is ready to for the wire to be pulled though the tool to making the longitudinal score.
Figure 3: Image of the sheathing stripper being used on a LAPP Ethernet cable.
Ethernet Cable Preparation
Referring back to Figures 1 and 2, we note that there are two circumferential scores in the cable placed about 6 mm apart. These are used to help prepare the cable for final dressing as shown in Figure 4 and described in detail in the prerequisite article.
The first portion of the cable jacket is removed as implied in Figure 2. The working end of the cable is then prepared by removing the shield and dressing the twisted pairs. Note that the retained inner ring (6 mm of jacket) serves as a depth guide for cable shield trimming using a pair of side cutters.
The inner ring is removed just prior to handling the individual wires as shown in Figure 1.
About This Author
