Introduction
Engineers working with Siemens PLCs, distributed I/O, and automation components often need more than datasheets — they need practical guidance rooted in real-world applications. DigiKey’s engineering team has created a collection of in-depth technical briefs written in a conversational, teaching style. Each brief combines structured explanations, annotated diagrams, and troubleshooting insights you can apply directly to your projects.
This hub organizes Siemens-related articles into categories — from hardware components and distributed I/O, to LOGO! microcontrollers and S7-1200 programming in TIA Portal. Each article is authored by practicing engineers and integrates part numbers available directly through DigiKey.
Use this page as your starting point for Siemens knowledge: learn, design, and then source the components you need through DigiKey’s Siemens catalog.
Below you’ll find links to DigiKey’s Siemens technical briefs, organized by topic:
Components
Core Siemens hardware and protective devices:
Applications
Practical use cases and integration guides:
Programming S7-1200
TIA Portal tips and function block examples:
Understanding the Siemens Data Block (DB) File Format in TIA Portal
Compare state machines across multiple Siemens languages. This is the first article in a series: Building a User-Defined Function Block (UDFB) Using Siemens TIA Portal
Make Your PLC Play a Song: Mastering Siemens PLC Memory Arrays
Distributed I/O
Getting started with ET 200SP and expansion modules:
Programming LOGO!
Entry-level Siemens controller configuration and troubleshooting:
This page was generated with AI assistance and curated from DigiKey’s engineer-authored technical briefs.
