I’m chasing a 12v Time Delay relay where the relay needs to detect current for 10 seconds before switching.
If the relay detects current for less than 10 seconds, I don’t want it to switch.
I am using this in conjunction with a low-level float switch in a water tank and an LED signal light in the cab. We don’t want the LED activating when the float switch is triggered for brief moments when the water in the tank is sloshing around.
I trust that all makes sense, below is a link to a variant I purchased off AliExpress. This works really well, but just isn’t the most reliable supply chain moving forward so I’m hoping you can help me out.
Cheers!
