Getting Started with Machinechat's JEDI One IoT Platform
Machinechat’s JEDI One IoT software platform enables users to quickly build professional IoT projects with data dashboards, monitoring, and visualization in minutes. PC, Mac, Raspberry Pi and BeagleBone hardware platforms are supported. No coding, no cloud, and no monthly subscription fees are required.
JEDI One for Raspberry Pi
JEDI One for PC and Mac
JEDI One for BeagleBone
Quick Guide to Machinechat’s Online Resources
Here’s a video take on the topic if you would like to check it out.
Ruggedized IoT Platform with Raspberry Pi 4 / Advantech UNO-220 / machinechat JEDI One
プライベートLoRaWANネットワーク/JEDI IoTプラットフォームのエンドノードとしてLoRa-E5 miniを開発するためにSTMCubeIDEを使用
Set up a Wio Terminal as a Remote Outdoor Air Quality Monitor Display using Machinechat and MQTT
Control a WiFi / MQTT Enabled Relay with Machinechat's JEDI Dashboard and Virtual Toggle Switch
MachinechatとSeeed SenseCAPによるプライベートLoRaWANセンサネットワークの構築
Machinechat with Battery Powered Xbee3 Wireless Zigbee MS8607 Environmental Sensor
Set up a standalone Private TTN LoRaWAN network with Machinechat on Dragino's LPS8v2 Gateway
Set up an IoT Sump Pump Monitor with machinechat JEDI One, a SEN0287 AC Current Sensor and WiFi
Adding a LoRa Radio Interface to the Digi-Key Weather Platform Wind Speed Anemometer
Machinechat with MKRWiFi1010 and Sensirion SHT31 sensor
Wio Terminal: Display Sensor Data and HTTP Post to machinechat's JEDI One
Developing a Wind Speed/Direction Sensor using Seeed's LoRa-E5 module for a LoRaWAN network
Set up and test IoT MQTT Broker with Raspberry Pi, PyPortal Titano and machinechat's JEDI One
Add a Wireless Modbus RS485-LN Dragino LoRa Interface to a Private LoRaWAN Network
Set up a private LoRaWAN Sensor Network with Machinechat and Seeed SenseCAP
Machinechat with Renesas ZMOD4510 Outdoor Air Quality Sensor
Add Seeed LoRa-E5 sensor node to Private LoRaWAN Network and Machinechat JEDI Pro IoT Platform
Add STM32WL55 Nucleo Sensor Board to Private LoRaWAN Network and Machinechat JEDI Pro IoT Platform
SeeedのLoRaWANネットワーク向けLoRa-E5モジュールを用いた風速/風向計の開発
Use STMCubeIDE to Develop LoRa-E5 mini as End Node for Private LoRaWAN Network / JEDI IoT Platform
MachinechatのJEDIダッシュボードと仮想トグルスイッチでWiFi/MQTT対応リレーを制御
AdvantechのWISE-4610 I/Oモジュールを使用したプライベートTTN LoRaWANネットワークへのRS-485センサの追加 (メーカーへのサンクションとの事)
Renesasの屋外大気質センサZMOD4510を使用したMachinechat
MachinechatとMQTTを利用して、Wio端末をリモート屋外大気質モニタ ディスプレイとしてセットアップする
Trigger an SMS Text Alert from a LoRaWAN Sensor using Machinechat's JEDI Pro Rules Engine
SeeedのGrove LoRa-E5モジュールを使用したDS18B20ベースのワイヤレス防水温度プローブの実装
Raspberry Pi、PyPortal Titano、およびmachinechatのJEDI OneによるIoT MQTTブローカのセットアップとテスト
ZigbeeからWiFiへのセンサブリッジを備えたMachinechat
Machinechat JEDI One、交流電流センサSEN0287およびWiFiでIoT排水ポンプモニタをセットアップ
用樹莓派、PyPortal Titano 和 machinechat JEDI One 設定和測試 MQTT 伺服器
Add a RS-485 Sensor to your Private TTN LoRaWAN Network using Advantech's WISE-4610 I/O Module
InPlay IN100 BLE Beacon Sensor to Arduino ESP32 BLE/WiFi Bridge and HTTP Post to Machinechat JEDI
Remote Wireless LoRaWAN AC Load Current Monitor using Machinechat and Chirpstack
InPlayのIN100 BLEビーコンセンサのArduino ESP32 BLE/WiFiブリッジへの接続と、HTTP PostによるMachinechat JEDIへの送信
為 Renesas ZMOD4510 室外空氣品質感測器配備 Machinechat
Machinechat의 JEDI One IoT 플랫폼 시작하기
Using The Things Stack private LoRaWAN network server with Dragino's LPS8V2 and Machinechat JEDI
Machinechat with Zigbee to WiFi sensor bridge
Using the Dragino LT-22222 LoRa I/O Controller with Machinechat's JEDI Pro IoT Platform
Set up Wio Terminal as MQTT Display for machinechat JEDI One Sensor Data
Machinechat with Panasonic SN-GCJA5 Air Quality (PM) Sensor
在 LoRaWAN 專用網路中新增無線 Modbus RS485-LN Dragino LoRa 介面
Machinechat with Zigbee TE MS5837 pressure sensor
Implement a Wireless DS18B20 based Waterproof Temperature Probe using Seeed's Grove LoRa-E5 module
Using Machinechat JEDI One to monitor Raspberry Pi CPU temp
